Hi all,
I'm looking for solid and reliable PSU for my PC; I need 550-650W unit which could replace my old Chieftec CFT600-14CS.
My PC is a bit old but a few years ago it was strong machine and after upgrading with SSD it works quite well. I'm going to use it for next 1-2 years but then it will probably still be used by someone from my family so I think it's worth to invest money in a good PSU.
After reading many reviews I decided to buy Corsair RMx. However, I've just noticed that it has 0 RPM fan mode - under low load the internal fan doesn't spin. While it is a big advantage if you have modern PC case (with PSU mounted on the bottom), it is unfortunately bad thing if you - like me - have old type of PC case with PSU mounted on top (just above the CPU area). In my old PC case the PSU is the main element which makes air to flow inside of PC, and I can't do anything to change it: my case has only 1 place to mount additional fan in the back and I already have it mounted.
In other words, I need a PSU whose internal fan spins all the time (of course it should be silent and be able to adjust its speed to the temperature, but I just want the fan to never stop itself); what's more, the bigger fan, the better (I prefer 135/140mm fans).
Could you please kindly advise me what PSU should I buy? As I told, I need 550-650W unit and I want the PSU to come from good manufacturer (I need solid and reliable unit). When comes to price, let's say that the price of mentioned Corsair RM650x is acceptable for me.
Thanks a lot!
Thanks a lot!
