- Apr 29, 2003
- 48,920
- 46
- 91
Let me emphasize that I'm not talking about laminate floors. Engineered wood floors are real wood. Basically plywood with a real hardwood veneer.
I've looked around and this is what I've come up with so far:
Pros:
- Engineered wood is more dimensionally stable; less prone to warping
- Engineered wood has a more durable finish than floors that are finished on-site, because they use some sort of UV curing process.
- (Non-issue) Engineered wood can be used below grade. I don't plan to do this.
Cons:
- Engineered wood is prefinished, which doesn't look quite as good as floors that are finished on-site
- Engineered wood can only be refinished once or twice; most hardwood floors are never refinished anyway
- Solid hardwood will last longer; engineered wood will last a very long time (20+ year warranty)
I've also found that:
- Engineered wood is very common
- Engineered wood is often thinner than solid hardwood (typically 3/8" vs 3/4"). Is that a big deal?
- Pre-finished floors are beveled around the edges to hide the fact that one edge might stick up slightly higher than another. Not necessarily bad.
Anyone have engineered wood floors and regret it? Anyone adamantly opposed to them for whatever reason?
Pros:
Cons:
