- Jun 14, 2003
- 10,442
- 0
- 0
im trying to place a web between a flat surface and a perpendicular protrusion that is a cylinder
the cylinder is protuded 30mm up from the flat surface i wanna put the web to.
|__________________
like above only the verticle line is part of a cylinder and not flat surface....i wanna put a web between the top of the cylinder to the end of the flat
i used the rib command picked my points, set the width every thing then it jus says it cant do it
any help?
|__________________
any help?
