soldering iron questions
ShadowBlade
4,263
so i want to make an xbox -> usb adapter
will a 30W soldering iron be enough for this?
is there anything else i need besides the soldering iron itself?
So
25,923
17
You need solder :p
Also, depending on the complexity and your experience (or lack thereof) consider picking up some solder wick / a solder sucker.
WackyDan
4,794
68
30 watts is plenty. Some mightconsider that a bit hot, but I've used a 33watt for years for most soldering jobs - but I've soldered probably thousands upon thousands of components and such. If you know what you are doing, a iron that's on the hot side will still do the job nicely if you are careful.
stardrek
264
Are you talking about converting a USB cable to xbox controller cable or putting xbox controller ports on your system? Either way a soldering iron is not needed. If you want to make a cable you can just twist the wires very well and use elctrical tape.
http://www.llamma.com/xbox/Mods/xbox_controller_to_pc_usb.htm
If it is for plugging a USB key into the xbox the above cable layout with a female end using a controller cable and you should be fine. That is what I did. They have the same wires.
Very helpful with cable layouts for pretty much anything you would want to do:
http://www.xbox-linux.org/wiki/Xbox_Linux_USB_HOWTO
Edit: Grammar
Edit: Spelled grammar wrong...jeeze.
JimPhelpsMI
1,261
Hi, Most sources recomment a 25 watt iron, but I find that to be a little too cool. 30 to 33 watts is plenty. Get 60/40 Rosin Core solder. The flux is built in and is for that type of work. Keep the tip well tinned. Practice on a scrap PC board first. Good Luck, Jim
GalvanizedYankee
6,986
Hey Jim,
My dual range RS iron,20&40watt, was not giving stable heat and the 20watt setting was near useless. So, the tip was removed, the threads cleaned best I could internal&external, then reinstalled with AS-5 :D So simple a fix it sounds silly in the telling.
Before the iron is plugged in, the tip is checked to be sure it's snug. The AS-5 is a secret, so don't tell anyone :p
...Galvanized aka John
JimPhelpsMI
1,261
Hi Gal, I was answering a guy who seemed not to need an expensive iron. My Weller Low voltage controlled heat rig with 600 to 700 degree tips works great for PC board work. I use a dual heat gun for heavy stuff. Standard simple iron at 33 watts works great. Jim
Googer
12,576
7
I was going to say the same. If he is asking a question like this then a 30 watt is probably too hot and he will probably destroy some components. Start with a 15 or 20 watt Iron and once you have learned how to use it and have used it a few hundred times then try using a 30 watt., but you will have to be quick with it.
