(Sold Out)Brother HL-2270DW Compact Laser Printer w/ Wifi, Duplexing $79.99
donfm
677
Newegg has the Brother HL-2270DW Compact Laser Printer w/ Wifi, Duplexing $79.99. There have been better prices in the past but in recent months this is about as low as I've seen it. $1.99 shipping.
http://www.newegg.com/Product/Produc...82E16828113545
I own this and it's been a very reliable laser printer for me. Generic toner cartridges are readily available and refill kits if you choose to go that route.
Kaido
Feb 14, 2004
51,223
7,052
I have about 20 of these at work. They are really good. Most of them are on Ethernet, although they do have Wi-fi and USB. Generic stuff is available. I have one at home too, they're great!
Pheran
5,740
35
I have this printer at home (use it on ethernet), works very nicely. Be aware that it has high startup current - the lights in my den dim slightly when it fires up. But my computer is on UPS so I don't have to worry about the voltage sagging too much.
Codewiz
5,758
I have the non-duplexing version. It is a workhorse and you can get generic toner on amazon.
donfm
677
I'm an electrician and if this is bogging down your electrical system dimming lights then you have an overloaded or faulty electrical system. I've never noticed even a flicker when this kicks in at my house. All Laser printers use more electricity that's just the nature of the technology.
So your light dimming warning is unwarranted for anyone with a correctly wired home or non overloaded circuit. I'd get your electrical system checked out by a professional. The circuit you have this on is highly overloaded.
CalebRockeT
1,142
13
Got in on this one immediately, early this morning when I received the e-mail from Newegg. I'm looking forward to finally having a printer shared on my network so I won't need to power on the computer that my current printer is shared from whenever I want to print something. I'm also looking forward to utilizing the full duplex printing!
Delbert
1,306
Thanks OP. Just what I have been waiting for.
It's too bad you cant have ethernet and wifi at the same time. Print from wired desktop or wireless laptop. You can pick just one.
gruven
39
I have one of these I use for school. It gets a lot of use and it is a trooper. Toner isn't expensive, and it is very small. Great printer, and it even works in Linux!
lothar
6,674
7
Why can't you just print from your desktop if the printer has wireless enabled? :confused:
I print both from my desktop and laptop. Only WiFi on the printer(HL-2170W) is enabled and it's not connected by ethernet anywhere even though it has the capability.
That said, I want Brother to release a printer that supports Google Cloud, so I can print from anywhere to home without having to leave my computer on.
Pheran
5,740
35
As lothar pointed out, that makes no sense. If it's on the network, you can print to it. Mine is on wired ethernet and I print from my wireless laptops just fine.
donfm
677
I assume his desktop does not have wifi capability in which case it makes perfect sense.
Fayd
7,970
www.manwhoring.com
no, it doesn't make sense.
if the printer is connected by ethernet, then it should be connected to the desktop, yes?
but the wifi router connects all things wifi to the ethernet. that connection should be largely invisible and seamless. so it should be connected to the laptop too. the only problem area would be if you were stupid, and put wired and wireless on different subnets.
KeithP
5,664
202
I have one these, one thing I would mention is I am not getting anywhere near the copy count from their "high capacity" toner cartridges that they estimate, 2,600 copies.
I just ran out of toner the other day, my current page count is 2,009 but that also includes the lower yield cartridge that the machine originally came with.
Maybe estimated page counts are like the EPA's gas mileage numbers but it is still disappointing.
-KeithP
Gillbot
28,830
17
-KeithP
They typically rate those numbers at something like 5% page coverage, which isn't realistic IMHO but what can you do....
donfm
677
You are wrong. If his desktop does not have wifi capability then he could not print via wifi if the printer is set to connect via wifi. Conversely he could not print from his laptop via wifi connection if the printer was set via wired ethernet to connect to the desktop. You can't have it both ways. The only way it would not make sense is if both printer and desktop were wifi capable in which case you would not need a wired ethernet connection. This is what everyone is suggesting he do but maybe he doesn't have wifi on his desktop.
jaydee
4,500
4
If the printer is ethernet connected to the router, the desktop can connect to the printer through the router. The laptop can also connect via wifi through the router.
If the printer is connected straight to the computer via ethernet, then its true, you can't connect also via the wifi feature of the printer at the same time. But I'm not sure why you'd do that. The easiest solution would be to connect the printer to the router, not the desktop.
CalebRockeT
1,142
13
Gonna have to agree with Fayd here. If the printer is shared over the network, it doesn't matter if it's connecting to the network in a wired or wireless fashion. It will be accessible by anything else that's able to connect to the network, no matter how that device is connecting. Connected to the network is connected to the network - wired or wireless doesn't matter in terms of sharing.
If you had to connect DIRECTLY to the printer to print stuff, and the router wasn't acting as a bridge to share the device in both wireless and wired circumstances, then what you're saying could make sense.
BlueWeasel
15,944
475
Got mine last year for about the same price and love it. The starter toner is about to run out so time for some more ink.
Any suggestions/deals for toner for the HL-2270DW?
slashbinslashbash
1,945
8
-KeithP
Yes, the "high capacity" ones are a rip. After trying twice and getting MAYBE 25% more pages than the standard toner cartridge (for almost double the price) I have decided to stick with just the standard cartridges. I have gone generic a couple of times, but really the authentic Brothers are quite reasonable at $45 (and I don't have to pinch pennies since I'm reimbursed for my supply costs).
I print around 1000-1500 legal-sized pages a month through this printer and generally buy a new cartridge, I would say, roughly every 3 to 4 weeks. I have bought one replacement drum unit (which is, ironically, pricier than the entire printer, and still pretty expensive even from the generics on the Internet). Drum unit replacement is recommended at 10,000-12,000 pages printed, IIRC. There are lights that blink at you irritatingly when the drum or toner is to be replaced.
Usually I can get about 50 more pages out of a cartridge when the toner light starts blinking at me (before the prints start showing noticeable light areas), but it's definitely a signal to head to the office supply store and have another one ready.
SparkyJJO
13,357
7
/facepalm
Wifi or wired ethernet, IT DOES NOT MATTER. Wifi is not direct wireless from computer to printer, but uses the router as the connection point. That router also handles the ethernet wired connections. There is no separation of ethernet wired and the wireless networks (except maybe in some special cases). Since everything connects to the router, everything can talk to each other. I set these things up all the time.
Do yourself a favor and go read up on basic home network 101 before you try to "educate" anyone on them :p
