Solaris 2.5.1 swap -s and swap -l commands
RalphTheCow
992
414
OK, this is a pretty arcane question, but what significance does the swap -l command have when the FREE number at the end is 0? The swap space (swap -s) gives a number for free space that seems fine 67000k on a 256 MB machine, but after running mkfile 12m /opt/swap, I think, to get a little more, the number for FREE at the end of the output for swap -l went from something like 2048 to 0. Everything seems to be running fine, but don't like this. Any ideas?
Sunner
I've never actually used Solaris 2.5.1, the oldest we have around here is 2.6.
But anyways, swap -l should list the individual swap spaces, while swap -s should list a summary of all swapspace, unless the swap command works differently in 2.5.1.
Sounds strange that you'd only get output for one swapspace with swap -l if you've got two.
RalphTheCow
992
414
I don't think I ever made it active with swap -a. I wonder if that is confusing the swap -l command.
But more importantly, any tips on how to find the cause of a steady erosion of free swap area?
RalphTheCow
992
414
No, /tmp is pretty empty. And today the swap -s is still decent at around 44000k (I think that compares to the 66000 before, allowing for 1 or 2 more X sessions open), and there is a little free space (176 blocks free out of 283664 total) shown by swap -l. Is a reboot likely to bring these numbers up? If there is a memory leak, would that also cause a swap leak?
