- May 11, 2008
- 22,721
- 1,486
- 126
In the "can you store electricity" thread, there was this post by metafor and it got me thinking.
Here are my thoughts :
There is an significant electric field between the earth and the upper sky. Continuously fed by the solar wind providing free electrons and ions. The only strange question remaining then is where do all these electrons and ions end up ? If the earth has been bombarded with hydrogen and helium ions for millions of years, where do all these electrons and even ions(single protons in the case of hydrogen) end up ? I would think reduction or increase of cloud formation is a possible suspect and fueling hydrogen to the earth where it will mix with ionized oxygen(meaning a single oxygen atom and not the general occurring O2 because of photodissociation) to form H2O or watermolecules.
From not so new research (i think by NASA and has been around give or take 15 years ) by the way, sprites, blue jets, pixies, gnomes and elves have been discovered (what is in a name
). Or lighting strikes (and EMP pulses creating a conduct to travel from the ionosphere down to the clouds) going up from the clouds to the ionosphere and above. This can mean there is a depletion of electrons or lonely protons arriving or that a surplus of electrons are arriving. Thus we get a fresh new amount of hydrogen from the sun in the upper sphere or electrons. And perhaps can be captured in by the magnetic field lines of the earth to be released at the magnetic poles of the earth. Or can be directly be captured in by the gravity pull of the earth.
I would think the solar wind from our sun can vary in different compositions from time to time. And that this perhaps can greatly effect the cloud formation on the earth. Combine that with a burst of energetic cosmic ray particles and we have an increase of the most potent greenhouse gas there is. Water vapour.
From NASA :
http://www.youtube.com/watch?v=0HAIN4BVwOA
And a quick look up.
http://en.wikipedia.org/wiki/Lightning
positive lightning or lightning where a positive charge is carried.
http://www.srh.noaa.gov/jetstream//lightning/positive.htm
What is this positive lightning made up of ? It has to be positively charged ions i assume?
EDIT:
Why i think this a recombination of an electron and a proton ?
http://apod.nasa.gov/apod/lib/glossary.html
An hydrogen atom is capable of emitting red light and most of those upward going lightning strikes appear red in color.
Is there by the way any news on the cosmic ray particle connection and cloud formation from Henrik Svensmark ? The last news i received was that the theory he and his fellow scientists proposed seem to become acknowledged by experiments at CERN.
metafor said:The reason that negative charges are usually associated with a corresponding positive charges is because for the most part, most naturally occurring elements are electrically neutral. To create a voltage, we have to then separate the positive and negative particles. But that doesn't mean they can't exist without the other. You can create a current with just electrons (lightning). You can't create a current with just protons unless you're talking alpha decay or firing entire atoms.
From NASA :
EDIT:
emission nebula: A type of nebula that shines by emitting light when electrons recombine with protons to form hydrogen atoms. The electron frequently approaches the proton in steps emitting energy as light as it gets pulled in. In one of the most common "steps," the recombining electron emits a photon of red light. Since many atoms in the nebula do this all at once, the nebula appears red in color. This type of nebula is created when energetic ultraviolet light from a hot star shines on a cloud of hydrogen gas, stripping away electrons from the atoms (ionization). The free electrons can then begin the process of recombination. Plural of nebula: nebulae.
