The house I am buying has a pretty pathetic asphalt driveway. I'm planning on replacing the driveway next spring. My dad is a contractor, and he has the equipment to to cement finish work. I am thinking of hiring some grunts to do the cement work on a driveway, and then me and my dad will finish it over a case of beer.
One thing I've always been interested in is alternative energy. A thought came to me that I should install a couple of loops of PEX into the driveway to take advantage of some of the sun's heat. I've come up with two possible uses, and thus two loops:
1. warm weather use
this consists of a loop that I can transfer my potable water into. Presumably it would be in front of the hot water heater. The cold water front the city service would be routed out to the PEX tubing int he driveway, capturing the heat stored in the concrete mass and transfering it to the water, thus lessening or eliminating the energy usage of the hot water heater. Possible add ons would be a recirculation pump and a device to remove air from the lines.
the system would only be utilized in the warm season and would be purged in the cool months via compressed air and a system of valves.
2. cold weather loop
this system uses a solar panel mounted on the garage to capture heat from the sun. A pump would be used to curculate antifreeze liquid from the solar panel to the driveway, thus heating the driveway to melt snow/ice. The system could also have a diversion valve that would route the fluid to a heat exchanger in the house for either hot water or warm air.
have any of you played with systems/ideas like this?
I'm in Iowa, so I'm pretty confident that the system would be fairly practical at least in the summer as a hot water source. PEX tubing is fairly cheap (~$30/100ft in McMaster catalog for 1/2" tubing)
Any thoughts?
1. warm weather use
Any thoughts?
