Solar System
Mar 16, 2005
13,856
109
Go in the X,Y directions are you might run into a planet or asteroids.
But what about the Z direction?
Mr. Pedantic
5,027
None of the planets as far as I'm aware have a significant Z component to their orbit. You have the Oort cloud, various comets and asteroids and such, but most of the mass in the solar system orbits in one plane.
Pocatello
9,754
I'm no scholar, but does it have to do with the rotation of the Sun? I remember something about angular momentum (high school physics class).
35,575
Winters are just too cold if your orbit goes over the sun's poles.
Fritzo
41,920
2,162
When you spin a ball on a string, notice how it stays within a plane parallel to the line motion? The same thing happens to the planets and most other things orbiting to the sun, only the "string" is the sun's gravity well.
There are a lot of small objects that orbit in the extreme z axis, but those are usually a result of some sort of collision.
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
The ecliptic plane, I believe, is defined as the plane of earth's orbit, i.e. we orbit at 0 degrees inclination. I'm pretty sure we're the only planet at exactly 0 degrees. Mercury is like 7 degrees, and pluto is way out.
z1ggy
10,010
66
Yup.
Going exactly along the Z axis in either direction wouldn't produce a collision with any planet.
I also found the rotational axis of the planets to be interesting as well. Cool how some are so different from ours.
zephyrprime
7,512
First, up and down is generally considered the y direction. Second - nothing is in that direction. Eventually you'd hit some other stars. Isn't this obvious?
Oct 25, 2006
11,036
11
You also have to realize we don't exist in the universe "right side up". The sun actually travels through the milky way at like a 40 degree angle, along with the rest of the planets at that orientation.
pete6032
8,418
3,815
Right. Our notion of up and down is arbitrarily set. This always made me wonder how all of the space ships in star trek just happened to all fly with their same side facing up, as it would be entirely possible to encounter an alien civilization where their notion of right side up was the exact opposite of ours and thus they would fly their ship 180 degrees flipped from how we fly.
Mar 10, 2005
14,647
if you're on a planet, there's very little that's open to interpretation concerning up and down. what your thinking of is a reference plane, and would apply to any 2 or more spaceships.
Jeff7
41,596
20
That can't be right. The possibility of successfully navigating an asteroid field is approximately 3,720 to 1.
Well those are the individual fields found within the rolling plains of the Asteroid Belt. They're pretty dense, especially in the two weeks before harvest.
