software to fix audio drifting?
SportSC4
1,152
i have a video where the audio is out of sync, it gets progressively worse toward the end. any reccomendations on software that can fix this problem?
Sureshot324
3,370
I'd like to know this too. I wish video players had the option to fastforward/rewind the audio a bit in the middle of watching a movie so I could at least resync it myself.
Gurck
Banned
Mar 16, 2004
12,963
Play around with Virtual dub. For a constant offset you can delay the audio or have it come in sooner (audio -> interleaving). A progressive offset is often the result of different length audio and video streams, you can match the framerate to fit the audio length (video -> framerate), or if they're the same length you can play around with cutting out some audio (or adding some) and then changing the framerate to match. For audio editing I like Audacity. Be aware that upon opening Virtual Dub the video is set to full processing mode by default. For doing what I described you want to set it to direct stream copy.
VirtualLarry
56,587
10,227
You need a better sound card, one with hardware timers (crystal-based) are the best. Onboard (CPU-driven) sound, generally has serious timing problems, because the timers are emulated in software, and depend on the CPU load at any given moment.
noxxic
254
If you just want to adjust it while you watch, Media Player Classic (not Microsoft) will allow you to do that. The filters ffdshow, Matrix Mixer, AC3Filter can also do it. All of these are at sourceforge.com.
