its GF2mx400 (hey its not mine) PCI card (he's got a brand name PC
it freezes up in games and 3DMark 2001SE (not that he runs it, but i use it to test it)
the onboard never had a problem but only renders in low tests @ 4-5 fps (the gf2mx400 does 40fps at least)
i tested the card in other systems and it runs fine, only freezes in this dudes system (C1.3, SiS chipset(?), 512 DDR Ram)
NB, CPU and RAM dont get hot, GPU does.
ok, now the interesting thing i found was looping 3DMark using Software T & L seems to (so far) fix his freezing problem.
to me this sounds like a VGA problem, perhaps getting too hot.
But i ran it colder in his system, a few fans, then the others that didnt freeze.
what is software transformation and lighting doing that saves the freezing??
faulty card ?? coolbits allows 0-100mhz mem setting
any hints would be appreciated
