Software for passwording system @ bootup?
Ladi
2,084
It should be a feature/function that you can turn on in your bios.
If you're talking about software to require a password before the OS boots, tell us your OS and we'll be able to help you better.
~Ladi
Shalmanese
2,157
In the bois, There should be a set Supivisor password section, set the password from there, Then go into advanced options nd change the security level or whatever it is called to system
Ladi
2,084
There are several free/shareware apps to lock win98 from unauthorized users. Search places like winfiles for win98 lockdown/security applications or search this forum for listings of several. The well-written ones cannot be circumvented by clicking cancel or by rebooting if used during a windows session instead of just at boot.
~Ladi
goldboyd
1,932
any easy way to do it would be to create a pw protected screensaver, and put it in your startup menu
fargus
626
a password protected screensaver in startup wouldn't be much protection... large window of opportunity, you can bypass it by going to safe mode, too.
Have used a few programs of this type... look for Full Armor or WinShield.
