SoftQuadro: claims to unlock gforce2 gts features like hardware AA -- is it true ?
Omer
203
ran across this SoftQuadro utlity here:
Linked
tried it out on my gforce2 gts but havne't seen a real difference.
claims to unlock all kind of features taht were once only reserved for the quadro series boards -- such as hardware accelerated antialiased lines
wondering if this makes sense to anyone out there ?
i also remeber some guy soldering his gforce2 to make it like a quadro ...
Deeko
30,213
12
Well, I don't know if that works or not, but a Quadro doesn't perform noticably better than a GTS in games. The Quadro's advantages come in professional 3D apps.
Rand
11,071
It works but I really don't see why the average person would care. The features that the Quadro has the the GF2 lacks have absolutely no effect in games.
Unless your doing professional level 3D rendering your not going to be gaining anything at all.
FireStarOmega
60
Has anyone gotten this to work?
Do the drivers have to be specific ones?
I tried with the 12.90 and nothing happened, it still detected the card like it was versus a quadro?
What gives?
am I missing a step?
pidge
Banned
Oct 10, 1999
1,519
I don't think it is supposed to actually trick the driver into thinking it is a Quadro. I think it just unlocks some hardware features. In order to change what the video card is labeled as, the PCI device id would have to change also. Dell does this with their drivers. They allow UBB with their drivers on a GTS even though this is really a Quadro feature.
Scope
1,324
It doesn't show up in your driver properties as a Quadro. You need a little prog called GLInfo to see if it worked. I originally posted this info here.
Scope!
FireStarOmega
60
alright thanks,
well I do heavy 2d and 3d work and I am used to working with a quadro. So I guess I will find out shortly if it does unlock the features,
Thanks
Patgod
182
a few other forums i post on have a similar thread. from what i read it works in windows 2000, not sure about 9x though.
nam ng
Banned
It does work under Win98SE, example... enabled AA-lines used to mean >50% FPS penalty for me, now undetectable when enabled -- GTS64MB, 12.90 driver.
