Soft modding Red or Black PCB 9500 into 9500 pro. Is it possible?
adlep
5,287
Is it possible to change the regular 9500 into 9500 pro?
If yes how would I do that?
Let me know
adlep
5,287
Weird!
ATI 9700 Pro - The GPU is clocked at 325Mhz, 8 rendering pipelines, 256 bit memory bus, memory is clocked at 310 Mhz
ATI 9700 - The GPU has been detuned to 275Mhz, still 8 rendering pipelines, 256 bit memory bus, memory has been detuned to 270Mhz
ATI 9500 Pro - The GPU is clocked at 275Mhz, 8 rendering pipelines, card is detuned to 128 bit memory bus, and memory is at 270Mhz
ATI 9500 - The GPU is clocked at 275Mhz, 4 rendering pipelines cut out to leave 4, 128 bit memory bus, and memory is at 270Mhz
So according to the spects, potentially it could be easier to make a 9500 into 9500 pro. This kind of mod would be potentially half simpler than the soft mod to the regular 9700...
To make a 9700 out of 9500 -> soft mod has to enable: 256 mem bus, 8 rendering pipelines
To make a 9500 pro out of 9500 -> soft mod has to enable: only 8 rendering pipelines....
:confused:
No. They have 2 COMPLETELY different layouts and associated hardware.
The only thing diffrient, according to the spects is the amount of rendering pipelines....
Alkaline5
801
According to Wizzard (the guy that makes the softmod) a 9500np based on the new PCB layout will become a 9500Pro instead of a 9700 if the softmod is used. The differences are all explained on his page.
kylebisme
9,396
actualy the memory bus is on the pcb itself, and the 9500s that you could make into 9700s were ones that used a 9700pcb, they don't make those anymore though. as for enableing the 4 extra pipes, that is what the soft mod did; why that would not work to make a 9500 into a 9500pro assumeing the chip has 8 good pipes is beyond me.
DRaG0nBLaD3
7
Yes, it can be done. Exactly the same way as the 9500-->9700 mod. Which you'll get depends on the layout of the card (L-RAM or Straight RAM).
alexkraemer
32
weren't the first 9500np's soldered to cut the pipeline down to 4? I remember the first 9500np mod involved resoldering in order to enable the pipelines
DRaG0nBLaD3
7
That was one way to do the mod, but then a couple of people found a way to do it purely in the drivers, hence the SoftMod.
