soda container deposits, how do they work
SarcasticDwarf
9,574
I need some quick info on this. I know you are charged an additional x ammount for each item, but how does the consumer get it back?
edit to clarify: Is there an infrastructure (beyond the regular recycling centers that most cities have) required beyond that of other states that do not have the deposit systems?
NutBucket
27,145
634
When you go recycle the can at a recycling center. It incentive to not just throw it out.
SarcasticDwarf
9,574
Ok, so it is just basically like a minimum price.
WannaFly
2,811
hah wtf? no.
If there is a 5 cent deposit you pay 5 cents extra when you buy it - take it to the recycling center and they'll give you a shiny nickle. dont, and you dont get yoru nickle.
SarcasticDwarf
9,574
hah wtf? no.
I meant how it actually works. There is no special infastructure (beyond the recycling centers that many cities posses) to support the system. In most cities, you get a price per pound for your returns. In this case, you would get a price per container.
NutBucket
27,145
634
hah wtf? no.
Uhm, it works out the same since its not exactly hard to know how much a can weighs.....
ViperSSD
317
in ny, the local grocery stores had can deposit sites where it would count the cans put into it, compact them and then spit out your $$. .....Is tht the infrastructure that you're talking about?
NutBucket
27,145
634
I think he means as far as where the recycling centers get the money they give you and such. It is on large network afterall.
AFB
10,718
hah wtf? no.
A lot of Grocery stores in those areas have machines for them.
SarcasticDwarf
9,574
ok, then maybe there is a specific infrastructure (above and beyone the normal recycling centers) required for it. I'm just trying to clarify for my poli sci midterm.
