Heres my deal: My rents have a machine that simply wont boot. Fans spin when you power it up, no video, no beeps, etc. I have tried a known good psu, and video card and it has 2 sticks of pc3200 ddr ram so i ruled those out as being the culperate. I reset the bios via battery pull, and have no other compatible spare parts. I'm guessing the mobo over the cpu simply because this is much more likely. The case is an old emachines case that seems to only fit micro atx motherboards and the cpu is a 3200+ socket 939. The motherboard is a Foxconn WinFast 6150K8MA-8EKRS. I went to newegg and they have 0 boards with these specs. The case looks rather cramped w/ a micro atx board in it so I am assuming that this is all that I could fit in it. I am open to other suggestions, but the rents really dont want to spend too much to fix this issue. Say 150ish for the entire fix dispite what is wrong. I am open to suggestions to either a new case/mobo combo in the 939 variant or a suggestion on where i can get a resonably priced s939 mobo. My only concern is the psu may be some emachines case-specific psu and i may be needing one of those as well. I will have to check on this. Any suggestions are appreciated.
