I have a 1ghz celeron on and ABIT BH-6 rev 1.0 running at 124 FSB (1.24ghz) with no problems. It seems the later processors of this core can run in the low to mid 1.2's OK, but the closer it gets to 1.3, it becomes very questionable. The 1.1ghz will be running at 1.36ghz when running at 124 FSB and that is most likely out of the range for this core.
For example:
At 105 FSB, it would be running at 1.15ghz (High Probability of success)
At 112 FSB, it would be running at 1.23ghz (High Probability of success)
Just try bumping the FSV 1mhz at a time, with stock voltage, intil it becomes unstable, then add a bit more voltage and continue the experiment.
You will find a point where more voltage will not help stability. At that point, back off the voltage to the last stable amount and then back off the FSB a bit, to give yourself a safety factor, and run for a while to see how it will do over time.
Good Luck, and Have fun.
