Socket 1155 vs 775 cooler differences?
Compman55
1,241
Online it appears the coolers are universal fit for 1155 and 775. I tried putting a intel heatsink assy from a 1155 only and older motherboard with a 775 and the holes are a tad off. Is this right or am I missing something?
Maximilian
12,604
15
Assy??? o_O
Yeah they're not compatable. 1156/1155/1150 are all the same, 775 is different. The coolers you see will use different parts or different holes on the same parts to mount onto 775.
Note the 3 different holes on the metal bits (two of them overlap). One is for AMD, the other is 775 and the last is a 1156/1155/1150 mount.
JManInPhoenix
1,500
The Zalman 95xx coolers seem to work on most Intel style boards as they come with all the different adapters for the different socket types.
Compman55
1,241
assy = assembly.
I thougt it was differnt even though you can;t tell by holding it up to each other. It must be every so slightly smaller, like 1/32nd of an inch.
