SoB Question/Problem
NicColt
I have two computers runnning SoB, one is running at about 600K and the other at about 328K the thing is that only the computer running at 600K seems to be posting numbers on my stats page. If both are running I should be getting aroun 930K cEMs/sec
I've now stopped the 600K computer to test and the 328K computer even though it's submitting to the SoB server successfully I get nothing. both are running 1.2.5 with exact same config. Below is a log from the 328K computer so everything seems to be ok but again no stats from that one computer. Any suggestions ?
[Sun Nov 14 17:06:18 2004] resolving hostname
[Sun Nov 14 17:06:22 2004] opening connection
[Sun Nov 14 17:06:23 2004] logging into server
[Sun Nov 14 17:06:23 2004] login successful
[Sun Nov 14 17:06:23 2004] n.high = 3011892 . 462 blocks left in test
[Sun Nov 14 17:20:00 2004] resolving hostname
[Sun Nov 14 17:20:00 2004] opening connection
[Sun Nov 14 17:20:00 2004] logging into server
[Sun Nov 14 17:20:00 2004] login successful
[Sun Nov 14 17:20:00 2004] n.high = 3018600 . 461 blocks left in test
One way to check if they are getting the info is to check the pending test Management page. Once you log into their site, go to the preferences page and click the link for Pending Tests.
Hope this helps
Also make sure the user name and team name are correct on both clients.
And remember that both of them have to have been running for 24 hours before the numbers on your stats page will match up with your actual production. Also, if there was a period where you had been assigned the tests but were not running the client, your rate will be reduced for the remainder of the test, as the stats work by showing the average speed over the whole test rather than the realtime rate.
