SoB: Need some help with the registry
SinfulWeeper
I installed SoB in a celeron computer and it finished it's first assignment. When I exitted the client to restart the computer it did not write the work it did to the registry and tried fetching a new WU.
If somebody can take snapshots of their LhDn/sob settings, I think I can force it to restart the current y string that is alread in there instead of downloading a new block which would hurt my stats.
Thanks 🙂
Here is my problem I copied and pasted from the log file:
[Wed Dec 17 19:37:04 2003] connecting to server
[Wed Dec 17 19:37:07 2003] logging into server
[Wed Dec 17 19:37:09 2003] requesting a block
[Wed Dec 17 19:37:13 2003] got proth test from server (k=4847, n=5259471)
[Wed Dec 17 20:26:51 2003] resolving hostname
[Wed Dec 17 20:26:51 2003] opening connection
[Wed Dec 17 20:26:54 2003] receiving from server
[Wed Dec 17 20:27:05 2003] server busy -- block added to submit queue
[Wed Dec 17 21:31:00 2003] block processing paused
[Wed Dec 17 21:31:25 2003] connecting to server
[Wed Dec 17 21:31:28 2003] logging into server
[Wed Dec 17 21:31:29 2003] block processing paused
[Wed Dec 17 21:33:27 2003] connecting to server
[Wed Dec 17 21:33:29 2003] block processing paused
[Wed Dec 17 21:34:05 2003] block processing resumed
[Wed Dec 17 21:34:05 2003] couldn't get block from server [can't connect], retry in 240 secs
[Wed Dec 17 21:34:11 2003] connecting to server
[Wed Dec 17 21:34:11 2003] couldn't get block from server [can't connect], retry in 240 secs
[Wed Dec 17 21:34:40 2003] connecting to server
[Wed Dec 17 21:34:40 2003] couldn't get block from server [can't connect], retry in 240 secs
[Wed Dec 17 21:34:50 2003] block processing paused
[Wed Dec 17 21:34:51 2003] block processing resumed
[Wed Dec 17 21:35:25 2003] connecting to server
[Wed Dec 17 21:35:25 2003] couldn't get block from server [can't connect], retry in 240 secs
[Wed Dec 17 21:35:28 2003] block processing paused
[Wed Dec 17 21:35:53 2003] connecting to server
[Wed Dec 17 21:35:53 2003] couldn't get block from server [can't connect], retry in 240 secs
[Wed Dec 17 21:35:56 2003] block processing paused
[Wed Dec 17 21:36:10 2003] connecting to server
[Wed Dec 17 21:36:10 2003] couldn't get block from server [can't connect], retry in 240 secs
[Wed Dec 17 21:36:23 2003] block processing paused
[Wed Dec 17 21:36:27 2003] connecting to server
[Wed Dec 17 21:36:27 2003] couldn't get block from server [can't connect], retry in 10 secs
[Wed Dec 17 21:36:37 2003] connecting to server
[Wed Dec 17 21:36:37 2003] couldn't get block from server [can't connect], retry in 10 secs
[Wed Dec 17 21:36:47 2003] connecting to server
[Wed Dec 17 21:36:47 2003] couldn't get block from server [can't connect], retry in 10 secs
[Wed Dec 17 21:36:57 2003] connecting to server
[Wed Dec 17 21:36:57 2003] couldn't get block from server [can't connect], retry in 10 secs
[Wed Dec 17 21:37:07 2003] connecting to server
[Wed Dec 17 21:37:07 2003] couldn't get block from server [can't connect], retry in 10 secs
[Wed Dec 17 21:37:17 2003] connecting to server
[Wed Dec 17 21:37:17 2003] couldn't get block from server [can't connect], retry in 10 secs
As you can see I have a k&n value already and it is in my stats page. ( http://www.seventeenorbust.com/stats/users/user.mhtml?userID=2204 ), but is I plug it back into the network, it will grab a new k&n value and lower my stats, maybe even put me in the negatives again like in the past. I want to avoid that under all costs, but I need a screen shot of the registry so I can direct the client to use what is already in the program files\sob directory in the hard drive.
Anybody?
Screen shots are relatively east... Alt+Prt Scr then paste in MS paint and post them or email me (email in my profile)
Maybe this will help.
Start->Run->"regedit"
Then goto HKEY_LOCAL_MACHINE\SOFTWARE\LhDn\sob
I belive there are three folders in there. I am mainly interested in the cache folder, although the third missing folder in the computer might be important also.
:|... I messed up. I restarted the computer and it grabbed a new test. Looks like I may hurt the people in my 3-1 race 🙁
Many thanks for the help though 🙂
This seems to be a common problem...you have to restart after installing the client and entering your username, but before downloading a new test...otherwise it will lose work and get a new block 🙁
Not sure why this happens, it doesn't happen on all machines AFAIK, but on a few it does.
Garry
