Edit: Looks like many are getting this problem
Have been running SoB for a couple of weeks using Version 1.1.0 and running as a service using the following commands to install and start the service:
sobsvc -i
sobsvc -o2
sobsvc -x
sobsvc -s
sobsvc -m
sobsvc -k
Problem: This morning I find the service trying to start one instance after another. I ton's on little 17's in my tray. Had to boot into safe mode and set the service to manual from automatic and then reboot back into WinXP. Tried starting the service from manual and same thing. So I uninstall the service using the -u command. Try starting SoB from the exe file and get an error message. Uninstall the whole SoB program and re-install the program thinking something is corrupt. Run the service install bat file above and the same thing starts all over again.
sobsvc -i
sobsvc -o2
sobsvc -x
sobsvc -s
sobsvc -m
sobsvc -k
