SoB & A Curious System Instability
Coquito
8,559
Last night, my "S" key was jamming. At least that's what I thought. The A, S, E, J, L, ;, all started crapping out on me within the hour. Granted, I never liked the layout anyway, but to have it die slowly like that was strange.
Soon enough, I reboot, thinking it just needed a fresh start. On the boot-up, I get a few system beeps, but that makes way for one long, continuous irritating tone. Oh, & for some reason, Firefox looses all my bookmarks, settings, everything. I couldn't recover my profile, any hint of it was gone.
I pulled the keyboard, & temporarily replaced it with a MS PS2, but the "Emergency Broadcast System" still persisted. I closed down my two instances of SoB & suddenly the noise stopped. I believe it was the CPU heat warning at the 90C degree threshold. I went into the bios, & apparently, on optimized settings, that warning buzzer is off. Just pressing down on the heatsink lowers the cpu reported temps from 70 idle, to around 50. This pc has never had anything close to these temperatures. Is the AS5 just plain evaporating away? The screws aren't coming loose, & all the fans are working; minimal dust collected.
So I try & start up SoB, thinking that "sensors are always inaccurate", & SoB is running at about 1.4-1.6 per core, when normally, they are between 3.2-4.5. So something is definitely odd here. Concerning the beeps, "long, short, short", is a memory error, as I did here that a couple times before the inevitable "This is only a test". I tested both sticks separately, but couldn't run Memtest86 because DOS doesn't agree with me.
This system is nearly a year old, & has experienced absolutely no problems, till now. I was even going to dabble a bit & see if i could get the clock up a little.
C2D 6300(stock)
GB GA-965P-S3(stock)
Fortron Blue Storm II 500w
Corsair ValueRam 667 (1GB x2)
Smoke
Distributed Computing Elite Member
Jan 3, 2001
12,650
207
I have had some problems in the last couple of weeks and I've seen others reports various errors around AT. I'm starting to believe it is the summer heat that is pushing some systems over the edge.
Coquito, has your computer room temps climbed very much?
I've been in discussions in the past where there seems to be a consensus that systems definitely degrade after a year of constant DC use. oops, I didn't say that in the DC Forum ... did I? :p :D
Coquito
8,559
The temperatures of course have gone up. The case temperature is still 39/40c, so whatever is suddenly pushing my cpu up nearly 40c definitely lives inside. I'm going to buy a better then decent hsf & hope for the best.
Completely stable, solid, then my keyboard gets has a heart attack & loses a quarter of its buttons on the left side. How that relates to my browser, I have no idea.
This is what I get. I didn't even run SoB all of last summer.
NicColt
4,362
how can that be.... that IS odd.
one thing I'm thinking is that maybe your CPU timmings are way out of wack...
I've read a few threads where users would underclock to get the absolute low temps only to find some of the symptoms you talk about.
try reloading your bios defaults and see if that helps it. I'm just guessing.
Coquito
8,559
I've always been at stock. I even went back, CMOSed it, set everything to optimized defaults & then just plain bios defaults. I reseated the hsf, layed the case on its side open, & I'm still getting mean temperatures. I don't hear that ugly note yet, but cores are at 1.47 & 1.57. I'll let them run through & start a new batch. Maybe they just caught a funky angle.
Alyx
1,181
My old roommate has that exact same board and his temp sensor is way wacked out, possibly your sensor also bit the big one. Maybe find a cheap temp sensor and see how different the core is from what you are getting from the MB BIOS.
Coquito
8,559
I used Core Temp v.95 & it kept throwing popups at me. The pc eventually shut down.
...but there's good news. :D
After grabbing a flashlight, I double checked the cpu. :Q
The AS5 was evaporating!
I'm very careful not to put too much gunk on my chips, so maybe it was spread a bit too thin last time. Actually, when I reapplied it the first time, the core shot up even faster. I just decided to put a pea in the middle & let the heatsink smooth it out itself.
Voilà!
:beer::D:beer:
TallBill
46,017
62
Blow out the dust on or around the hsf. I have a pc that overheats and beeps if the dust bunnies build up. I disassemble the hsf, wipe it out, and good to go.
Smoke
Jan 3, 2001
12,650
207
Voilà!
:beer::D:beer:
I should have thought of that. Freewolf put me onto redoing the AS at least once a year.
So are you good to go now?
Coquito
8,559
Ooh ooh! Where are we going? :p
/puts on shoes backwards
/plªys ??-h chå®a?ter map while researching new keyboard :)
Ken g6
Moderator
Dec 11, 1999
16,616
4,532
75
:music:
A hunting we will go,
To catch a giant prime,
A hunting we will go!
:music:
Don't anyone forget their LLR BeatStick (or SB or PRP stick.) ;)
VirtualLarry
56,571
10,206
Pretty simple. Sounds like thermal throttling to me.
You can download CPU Rightmark and run it, it will tell you if you are throttling.
VirtualLarry
56,571
10,206
If you can push down on the HSF and cause temp changes, then obviously the HSF is not seated correctly, or is not firmly attached. Remove it, re-apply paste, and if that still doesn't work, replace the cooler altogether.
VirtualLarry
56,571
10,206
Was the AS5 old? Did it start to seperate out? Perhaps it was defective? (I don't see how silver particles can evaporate.)
