So why is diesel more expensive than gasoline?
SSSnail
17,458
83
86
I thought and thought about this, and haven't come to any good conclusion why diesel is more expensive than premium gasoline around here. No, we don't need to heat anything.
Any thoughts?
pyonir
40,856
321
I thought it was because of the refinery process...it's more expensive to make or something? :shrug:
EightySix Four
5,122
52
More energy per liter or gallon.
One gallon of diesel is 147,000 BTU, while one gallon of regular unleaded is 125,000 BTU.
SSSnail
17,458
83
86
Me tap sarcasm meter :confused:
destrekor
28,799
359
good question. Less than a decade ago diesel was cheaper than 87 octane fuel. It's supposed to be a less refined crude product. Maybe more of crude oil is going into the production of regular gasoline and less is available to be refined as diesel?
SSSnail
17,458
83
86
Originally posted by: PottedMeat
Maybe you get less diesel per barrel of crude than gasoline?
Stop it, you're gonna really break my sarcasm meter.
EightySix Four
5,122
52
No, diesel is cheaper and easier to refine, which is why it used to be cheaper at the pump.
Oil/Gasoline companies have realized that diesel has more energy per gallon, so a small diesel vehicle can outperform (at the low end) and get better gas mileage than a standard gasoline vehicle, so they raise the price to make us less likely to buy a VW TDi or equivalent. (slightly conspiracy theorist approach)
edited for clarity and stupidity on my part
pyonir
40,856
321
Edited for clarity. Simple answer is tax rates between diesel, gasoline, and ethanol. Diesel is taxed higher by the feds, and in most cases by states, but not all of them.
Fed tax rate is 18.4 cents for gasoline, 24.4 for diesel, and 13.1 for ethanol.
States vary for example the largest difference I can find is Pennsylvania:
31.2 for gasoline, 38.1 for diesel, and 16 for ethanol.
So essentially you have an enviromental bias to steer you in the form of a tax.
Two other reasons are:
-High worldwide demand for diesel fuel and other distillate fuel oils, especially in Europe, China and the U.S. and a tight global refining capacity available to meet demand.
-The transition to low-sulfur diesel fuel in the U.S., which is affecting diesel fuel production and distribution costs.
From http://www.biodieselnow.com/forums/t/19309.aspx
Reputable? I dunno...but the main theories seem to surround around supply and demand and taxes.
Fenixgoon
33,281
12,842
supply and demand - diesel is a certain fraction of refined petroleum, so based on yield alone per barrel/ton/gallon, price may vary. then you have demand - only have machinery really uses diesel. If consumers started using diesels in large percentages, price would go up then come down (due to the increased demand, low supply, then eventually equilibrating of supply/demand)
<-- not an economist
frostedflakes
7,925
The new low sulfur requirements probably increased cost of production. Also the US government may tax it more because it's mainly used for industrial and commercial applications. I think the reasons diesel is cheaper in Europe is because governments don't tax it as much as gasoline, and I don't think theirs is quite as clean as ultra-low sulfur diesel now required in the US.
EDIT: Looks like pyonir beat me to it. :)
cheezmunky
298
has to do with supply & demand and the amount of diesel yielded from the current refining process in the US
...or so says the latest car and driver
ades
108
To maximize profits?!
Sometimes diesel a lot cheaper than regular, sometimes more expensive, it is a true mystery.
OdiN
Banned
Mar 1, 2000
16,430
Because cars can go farther on less so they have to charge more now since more deisel vehicles were becoming more popular.
AlienCraft
10,539
Any other answer ignores why Oil Companies exis / Capitialism Law #1: Make Profit at any cost.
That any other benefit is derived is none of their concern, except if it disrupts their business model.
FoBoT
63,084
15
fobot.com
supply/demand
those big trucks on the highway carrying all the crap we buy at walmart and target and the grocery store use diesel
diesel >>>>>>> gasoline
