So...what's the verdict on IE7?
DanTMWTMP
15,906
13
Originally posted by: archcommus
Originally posted by: 40sTheme
I don't like it... it leaves the iexplore.exe running when I close it. I have to go end it from my processes. :s
I don't have that issue.
:confused:
I don't have that issue as well. and ya, ieSpell addon is just as nice as the ff one.
Zenoth
5,196
197
I like it, but with it installed my ATi Tool gets buggy, and my voltage settings completely disappears.
If I go back with IE6, then ATi Tool is back 100% functional.
No, I don't get it, but I don't want to try and figure out why. So I'll keep IE6, un-used, with Firefox 2.0 as my main browser.
Oh, also, with IE7 installed my Natural-Selection crashes upon loading most servers (that's a Mod for Half-Life). Another reason for me to stay away from it. They (Valve) have released an update recently which was supposed to fix that very issue, and it did, but it only works with Team Frotress Classic and the original Day of Defeat as I tested them. On the other hand, it didn't work for N-S, which I play each days of the week and a lot during week-ends.
Strange ... how can it cause such bugs that aren't even related to web-browsing and affects other applications is beyond me, but hey, that's from Microsoft so anything is possible really.
QueBert
22,546
832
IE7 still doesn't follow CSS rules, I had a bitch of a time getting my CSS to look right in IE and Firefox together. POO on IE, IE7 is teh junk0r
BFG10K
22,709
2,995
Like in all images or just ones with lots of solid color patches?
I've seen it in both kinds but it's quite rare that it happens (and quite random too).
You can load an image and see it but then when you reload it the problem's gone.
Anubis
78,712
427
tbqhwy.com
i installed it cause it was a crtitcial update
10 min later i wanted to uninstall it, just because oftewr looking at it i hated it
i cant figure out how to get rid of it
i use opera 9 tho so it doesnt really matter
MrChad
13,507
A LOT of work was done to improve CSS compatibility in IE7 throughout the beta process. The developers worked extensively with beta testers to improve things.
One major difficulty is that so many sites designed to work with IE6 also need to work with IE7. That means keeping older "quirks" around while improving compliance in "strict" mode.
http://blogs.msdn.com/ie/archive/2005/09/02/460115.aspx
trainmaster5
35
I installed it as a MS update. Now "Ding" from Southwest Airlines won't work at all.I've un installed it but Ding is still a no-go.
mechBgon
Oct 31, 1999
30,699
How about in Add/Remove Programs? :) Windows Internet Explorer 7. Although I think it would be best from a security standpoint to keep the latest version of IE, and keep it updated, regardless of whether you use it yourself or not.
IE is still the only browser you can deploy, configure, manage and update en masse using Group Policy and WSUS, AFAIK. People with a few hundred (or a few thousand) browsers to manage and update on a month-to-month basis might have something positive to say about IE7 ;) Where's the competition on manageability?
Snapster
3,916
Much better than IE6 in almost every way. However, I can't live without my mouse gestures in FF.
Captante
30,316
10,814
My primary browser is Opera 9 but I did install IE7 recently & overall I like it a lot, except that I'm having strange Java-related problems in certain websites... for example here on ATOT the reply & quote buttons are none-functional.. worked fine in IE6 & still work fine in Opera & FF.
One major plus however is that since installing it, I havn't found a single piece of spyware on my PC vs finding stuff on virtually every Counterspy scan before.
Sureshot324
3,370
It's not bad but not enough to get me to switch from FF 2.0. Some of the changes they just made for the sake of change, like moving the refresh and stop buttons to the right side of the address bar (any way to change this?) and replacing the menues with icons. I guess they wanted it to look new after not having a significant change in IE for like a decade.
Beller0ph1
1,302
I'm not going to use it until I have to (when Microsoft pushes it to us via Windows Update). Firefox rox
oslama
3,102
32
i had 2 crashes with first hour of installation.
The fonts are fuzzy even after turning of cleartype.
JustAnAverageGuy
9,057
IE7 is definitely a *VAST* improvement over IE6, but it won't be replacing Opera 9 as my first choice any time soon.
- Newbie
Gooberlx2
15,381
Originally posted by: So
While I could care less, and haven't tried IE7, everything I've heard (so take it w/ a grain of salt) says that IE7 is between FF1.0 and 1.5 in quality. FF2.0 is already another generation ahead.
I disagree, FF 2.0 is hardly a "generation ahead," it's more like an FF 1.6. There are no next-gen browsers out right now really.
IE7 is a huge leap over IE6 and is actually quite functional as an FF replacement unless you need your extensions and gestures.
Last I used IE7 it didn't remember sessions or have mouse gestures. Without those two options it still lacking for me. Has it changed in the final release?
Jaxidian
2,230
twitter.com
As a user, I love IE7. As a developer, I hate it - another browser with significant changes that I now have to test for.
FF2 I loved from a dev's standpoint because it was so similar to FF1.5 but from a user's standpoint I was pretty disappointed it because it was so similar to FF1.5.
:p
alkemyst
83,769
19
As a developer, I need to use it.
The text quality seems fuzzy though...anyone know a solution. Using a Nvidia 6800GT if that matters.
FF is nice too. IE7 may *MAKE* me switch to it at home though.
FVCKING SEARCH N00B:
Fuzzy text in Internet Explorer 7 (IE7)
The information in this article applies to:
ZoomText 8.xx
PROBLEM
When using ZoomText 8 in Internet Explorer 7, magnified text may appear fuzzy and difficult to read.
CAUSE
Internet Explorer 7 uses Windows? ClearType feature to smooth the edges of screen fonts for clearer, more legible viewing (in unmagnified screens). However, when magnified, the clarity of ClearType text degrades significantly.
SOLUTION
To resolve this problem, disable the ClearType option in Internet Explorer 7, as follows:
On the IE7 toolbar, click on the Tools > Internet Options.
The Internet Options dialog appears.
Select the Advanced tab.
Scroll down to the Multimedia heading.
Uncheck Always use ClearType for HTML.
Select the Ok button.
Restart IE7.
lollerskates.
BFG10K
22,709
2,995
I like it but I wish the menu bar was at the top like regular programs.
fierydemise
2,056
Definitely better then IE6 but I've gotten so used to my extensions (especially mouse gestures) that I can't really switch back from firefox.
