so what games will use doom 3 engine?
adelphi
Banned
other than f.e.a.r?
is it true ID will take another stab at making a sequel for rtcw, i thought they scrapped that
idea and end up releasing the multiplayer playtest for it....
i thought that was a much better game than doom3
there's no advance physics model in id's engine (vs valve source engine) right?
hopefully as little as possible...
My friend has an athlon xp 1800 and 5700 ultra video card, and he can't run doom 3. i have a 2600 and 5200 ultra 🙁
something's wrong then. both systems should definately be able to play D3, the former at MQ, the latter at low...but it should work...its playable on a p41.5/ti500. oh well
quake 4 will use the D3 engine.
-Vivan
did you try lowering the settings?
640x480 @medium looks fabulous still...
hopefully lots and lots
tons of games with high requirements = more video card sales = my nvidia stock drama over
besides
whatever is made with it, as long as its not as dark and depressing as doom 3, should look really pretty
Something is definately wrong with that (first) system. I have an 1800+ and an AIW Radeon 9700 Pro and I can run it at 1024x768 and High graphics just fine. Smooth as silk.
Make sure you apply the config fix though because that makes a huge difference.
