- Mar 6, 2006
- 6,490
- 1,022
- 136
I see now that the ones you posted have etching on them (Ive got a 24" 2048x1536 so the tiny thumbnail didnt have detail untill I enlarged it). One even looks like its cut through? How do those work, I saw one block looked like it only had a single inlet...wheres the water go?
So if its all about high flow and turbulance then my idea still seems to stand, a large block with lots of thin dimpled fins (like I said, kinda like a heatpipe tower) so a large ammount of water can pass through but there is also more surface area to transfer heat. Im not talking mass, big difference.
And that thing about nozzles forcing water into a plate? Is that increasing pressure or something, how does that help? Dont get to technical, Im trying to actually understand this stuff lol. I can understand that a thinner material between the actual CPU and the water would be good, as that material is going to trap some heat. But you cant go to thin or it will flex when you mount it.
All of this is making me want to expiriment with my setup. My pump says 12v, 400L/Hr, 3/8" hose (inside diameter?), ceramic bearing, 70,000 MTBF, where does that rank in the grand scheme of water pumps?
