- Sep 7, 2003
- 1,531
- 1
- 71
Originally posted by: nodoubts2k
Originally posted by: MercenaryForHire
You blew a tranny? :Q
- M4H
well, i dont know exactly. The car has been parked for a while, and I dont know its prior condition. As i said, I only had it for about a month, then the reverse stopped working and now the gears are slipping, so I parked it and am not using it.
- M4H
What kinda of fluid did you use? If the fluid has never been changed, and you did it when you got the car, you may have just dislodged some dirt in the tranny. Do another drain and refill with dexron III, mayb even two or three with some miles inbetween (50 miles or so), chevron atf is a very good inexpensive atf, works great in the 91 toyota previa i service. If there is a transmission drain pan, drop the pan and replace the filter (buy it at napa, wix is about $15 for the filter kit) before doing the drain and refills. Better to try and fix it for about $50 and some of your own time then to call the tranmsision dead.
Originally posted by: thomsbrain
god i hope my transmission holds together. 165,000 miles on my accord. i need this car to last to 200,000 so i can get out of school.
- M4H
I did it at my uncle's shop, some kind of generic fluid (i believe it said dextron III). I cant really drive it because the reverse doesnt work at all. We replaced the filter and the gasket already.
