- Feb 17, 2005
- 4,682
- 1
- 0
So, as of this morning, my computer wont turn on. The power supply seems ok, it makes that faint reasuring hum and the usual chirp when power is removed, but the mobo recieves no power. The power LED isn't on, and of course it doesn't start up. So, the question: I'll have to RMA either component to test which one is borked, as I don't have another power supply handy that has the wattage to turn my machine on. So do I try RMA'ing the PSU first, or assume it's the mobo? Also, if this helps, my vapochill control unit, which sits between the power switch and the mobo, basically a power relay, sits thier and says "Checking MB Status" durring power on. So, which component to RMA first?
