So my nephew accidentally locked our garage lift door...
icejunkie
2,326
Pressed some sort of Lock key from the inside before closing the door and now it can't be opened. It's a LiftMaster and I don't have any access into the garage besides the main lift gate...
Any ideas? besides breaking the door....
So
25,923
17
Run at the door repeately hoping your molecules line up perfectly for you to pass through?
Jawo
4,125
I know theres a manual spring loaded lock that you can twist to send arms into the track....havent heard about an electronic lock.............you have a key to the lock on the garage door?
icejunkie
2,326
no, it's electronic... just press a button...
Baked
36,052
17
Bang your nephew's head against the garage door and hope his big empty head knocks the lock loose.
AgaBoogaBoo
26,108
Originally posted by: icejunkie
Originally posted by: AgaBoogaBoo
How did he get out? Locked it before you closed it so then once it closed down it was locked?
yes
Try turning power to all that stuff on and off from the breaker, maybe you'll have to leave it off for a few minutes. Hopefully it gets "reset" and you can open it again.
GeekDrew
9,099
19
yes
^ That does work sometimes, depending on the manufacturer :D
