What do you think I should do to replace it? It was a 20" trinitron
so I'm used to large monitors and would like to get another one, however,
the thing was huge and weighed a ton. I don't think I'd want one quite
so heavy. Right now I'm using an older 17" monitor I had around.
I figure I have 3 choices:
On the one hand I think dual monitors would be cool, however it might be better
in the long run to get a good quality crt now and a lcd later. (That would be more expensive though)
What do you think would be best? And if you have specific monitors that you think are good, that
would be extremely helpful.
- Buy a 19" quality monitor
- Buy a 17" lcd and use it with the 17" crt i have now (I have a 9800)
- Save up and buy a bigger lcd
