OP Start using one of these and you will never have to deal with the drain plug.
https://youtu.be/ZPflVUzVxJ8
1. They don't get all the oil out.
2. They won't get any sediment out if very little.
Those vacs are great for lawn mowers. They are great at needing to partially empty or do a very quick and not done right Transmission oil change, but I'd never use one to change oil on a vehicle unless I had no other option... For the OP, if he was unable to get the drain plug out and didn't want to fix that, then yes, an oil vac would be a solution, but these tend to be a bit pricey for a decent one vs the cost of a bolt extractor and new plug no?
I have one I use for my lawn equipment. Love it for that.
