So im making a car puter
WarDemon666
Anything around 1ghz, 256 megs of ram is enough..
getting a lilliput 7" touchscreen, just want to know, will a usb extension cable be good to bring the touch screen from the front of the car to the back? or do I have to put the computer somewhere up front?
Also, im going to buy a 12V power supply with a built in shut down controller, they are like 100 watts or something, is that going to be good enough?
Thanks for all advice
I already built the system, just waiting on monitor until i have some cash. If you click on My System at the bottom you can see what's in it.
It's based on the Shuttle SN95G5 V2.
When I do get the monitor I am also going to buy an ATX mobo and a much lesser 939 CPU. Then I'll throw the lesser CPU into the Shuttle, throw in some cheap memory, and put the 3200+ in my tower.
LOL well it's not bottom of the line either.
The far bigger problem in my system is the FX5200 🙂
Maybe I wouldn't move the 3200+ out. It would all depend on when I am ready to do all this and what prices are at the time.
www.mp3car.com for the lcd...
id apprechiate it if someone could find me a decent SMALL mobo, and the cheapest cpu for it around...
1ghz is plenty, i will only be playing mp3's, movies, and GPS software
Thanks.
