- Apr 6, 2002
- 7,141
- 1
- 0
I want to give my 1995 Geo Prizm a tune up. My basic plan is to replace my spark plugs, spark plug wires, distributor cap, and rotor. To do this, I'll buy the following parts from Autozone:
4 Denso Standard Plugs - $1.69 each, part #5016
Wells Ignition Rotor - $2.79, part #DR925
Wells Distributor Cap - $26.99, part #JD974
Double-silicone wireset - $35.99, part #9019
I have the factory shop manual for my car, it recommends NGK or Nippondenso plugs. Does it really matter? Choosing blind I'd probably take Bosch Platinum plugs, just because it's a good name.
As far as the ignition rotor goes, I can also get a Beck-Arnley model for $11.50. Should I? Why is that one more expensive?
For the wireset, I can also get a Bosch wireset for $49.99 or a Beck-Arnley wireset for $74.75. Again, does it matter?
Anything else I should know before I start? My uncle's going to be helping me since he's fairly good with cars.
