Originally posted by: fbrdphreak
So here's the story. I pulled my 6800GT out of my mobo the other day, machine was powered off, but the PSU was still switched on.
Put 6800GT back in, no go.
Would this damage the mobo or video card or both?
Yikes!
Like ChiPCGuy said, in future be paranoid about power when tinkering with your system. Always power down, and unplug the PSU (pull the cable out of the PSU after shutdown), hit the power button again (once the plug is pulled. Mind you with soft-off, there is a debate if this does anything or not) and let your system sit for a while (allows residual charges to subside. Yes, it is an old IT myth, but it is a good one.)
Now what?
Well, it happened so you need to identify the damage. Always look at the parts for scorching, broken capacitors or burnt traces. If you see it on your motherboard or video card, assume that the part is toast. You need to remove the parts to inspect, and
you must inspect the back of the motherboard as well.
No visual damage, then follow these steps.
Test motherboard:
1) Power up the system after assembly, listen for diagnostic beeps - look for video. Problem, go to 2) No problem go to 4)
2) Power up the system with a different (and expendable) video card, listen for diagnostic beeps and look for video. Problem, go to 3) No problem go to 4)
3) If you can't get video with another AGP card, assume that the motherboard is broken. You need to test your other components on a good motherboard (i.e. CPU, RAM, PSU (yes, really), PCI expansion cards (sound/lan/ide/modem/scsi/etc.)), hard drives. The other components could have been affected if there was a voltage spike or other electrical problem on the motherboard. Skip 4)
4) You may have lucked out. Make sure, stress test your system and look for problems (memtest/prime95/S&M/Sandra Burn/etc...)
Test Videocard
1) Test video card in other system. Does it work (i.e. post)?
Yes) Run OS diagnostic programs (ie. dxdiag, video games (opengl and d3d), etc.) look for artifacts and video corruption. If its ok, you lucked out.
No) Really look hard at the board for visual damage. If you can't see anything, it means a chip (or chips) was toasted. Your AGP card is dead.
Good luck.
