know of fence
Don't you think it is strange how people lambaste the FX-8150 in unison? Is it possible that the emotional consensus is at least partly groupthink, triggered by the desire to have clarity and simple answers?
Let's not forget a CPU architecture not only consists of transistors but also a million compromises. When at the end of the day two things remain: performance and power consumption, there is a multitude of ways to distort the perspective.
So let's take a look at reviews: Take this-here-site for example. I'll spare you the quotes.
Anand gives praise when video encoding is benched, which is pretty much the only mainstream thing requiring a massive CPU. So far, so good.
Then he comes down hard on single threaded performance...
(Update: Crysis effectively makes use of two cores, we see the biggest disparity here, presumably since Intel can utilize a half while AMD uses one forth of its core potential).
Last but not least, power consumption under load is high.
So what is your mental picture after that, let me guess: A CPU that can barely run games and devours 229W while at it.
But if old game performance is bad, due to a lack of parallel threading. Shouldn't power consumption during games also be reduced?
Alas, we are never provided with the numbers Anand chooses to present only min and max. I dare you to find a review that has more numbers on gaming power consumption.
In Conclusion
Wouldn't you agree, that maligning SINGLE THREAD PERFORMANCE while only presenting PERFECTLY MULTI THREADED power consumption may be a little bit misleading?
Power consumption still is a deal breaker compared to the i7 2600k for me, but I really would like to know if low performance in those games at least resulted in lower consumption. Then again it may turn out that the 8 core Bulldozer actually scales pretty well with its tasks, surely we can't have that.
(Review)http://www.anandtech.com/show/4955/the-bulldozer-review-amd-fx8150-tested/11
Update: As an enthusiast site AT never put much emphasis on power consumption, only reporting total power at the wall outlet. Supposedly because in a world of silence lovers and power savers desktop computers would only exist in their mini-ITX variants.At least modern desktop hardware throttles down the power and shuts down unused cores, which is one of Bulldozers strengths compared to older Phenoms.
Chart from X-Bit Labs shows idle W measured at the 24 pin connector)
The Questions about single threaded power consumptions were also answered in this topic, thanks to LoneNinja. As well as the issue of performance scaling thanks to frostedflakes; power consumption scales from [>63% to 100%] in almost linear proportion as the number of threads is increased.
In Conclusion
