So, for Oblivion, HDR or AA?
Todd33
7,842
HDR looks great, except the super glowing faces of people. The 360 has HDR and AA, but the res and draw distance is poorer.
Munky
9,372
Right now I have HDR enabled. I tried AA+Bloom, but HDR seems a lot brighter, and I dont notice the jaggies much in this game.
SPARTAN VI
803
In photo composition, high contrast images generally look best. Translates well into gaming as well; HDR really adds color and depth. I'll take HDR over AA+Bloom.
videopho
4,185
29
The game looks better in HDR in my AMD rig but it had caused freezes, especially outdoor. I now have my 7800gtx set @ Bloom and have not had a glitch since. That said, Bloom or AA is the only choice I get.
Ryan Norton
170
IMO the HDR effects in Ayleid ruins, where sunlight or strong glow from the ceiling crystals come in, are about the best looking real-world game visuals I've ever seen. I really only notice jaggies in towns where you have strongly geometric models and lots of straight lines on buildings. I'm sticking with HDR for now.
aka1nas
4,335
HDR isn't terribly noticeable or pretty unless you are Oblivion or some dungeons. The jaggies bug me then too. It does make the lava look really pretty though.
RobertR1
1,113
At 1920x1200, I can't really tell between AA on or off esp. since I can only use 2xAAA. I've switched over to HDR now. It looks better, to me.
CJP
512
Where in the Nvidia drivers do you select HDR (I've got a 7800gt sli setup)?
1Dark1Sharigan1
1,466
Actually after playing with HDR for a while, I've decided I can no longer go back to bloom+AA. HDR just simply makes the game look more dynamic.
Munky
9,372
Originally posted by: RobertR1
Originally posted by: munky
You have to enable HDR from the video options menu in the game.
You get your performance issues fixed? :(
No, I'm still chugging along at ~30 fps outdoors at 1024x768. I added the high res textures, though, so at least it looks better and the performance didn't change. I hope it's not due to thermal throttling, because it reaches 89C under load. But I still did not update to cat 6.3 (too busy playing...), so maybe that will improve it somewhat.
Raduque
13,140
138
Originally posted by: DOACleric
My 9800XT can't even run with HDR in Oblivion (its greyed out), so bloom is your only option. Not that i'd pick HDR anyway - the difference is negligible (at least in my experience with HL2), and the performance hit is drastic.
For you. HDR in Oblivion and HDR in HL2:LC are two completely different animals. It looks 3x better in Oblivion compared to HL2:LC. And yes, the performance hit is drastic, but believe me.... it's worth it.
LiekOMG
1,362
Been playing for over a week now with Bloom + 4xAA, and i'd never even consider the HDR option. First, the 4xAA doesn't even hurt performance for me (compared to AA off) while HDR really seems to kill performance. Also, there seems to be a "bug", if you can call it that, where the bloom effect is greatly enchanted by turning AA on, and looks very close to HDR. I actually find that HDR looks way too bright and overdone in dungeons.
videopho
4,185
29
OP- Change it to a poll type of question. I wanted to see what the percentages are. My guess is HDR but who knows?
tuteja1986
3,676
http://www.gamespot.com/features/6147028/p-2.html
check the Xbox 360 versus High-Spec PC
just put the move over the image to see PC screenshot. Look closely to Ground and you will see XBOX 360 HDR with AA sunlight looks better... but PC screenshot has much better textures and draw distance. So if the developer put the damn HDR with AA feature or ATI some how enable it or some finds how to turn it on :! it would be awesome ;)
Rhezuss
4,118
34
HDR for me. I tried AA+Bloom and it's quite horrible (for me that is :p).
RobertR1
1,113
This game has absolutely beautiful HDR implementation. Hopefully other gaming studios can learn from this!
