It started for me after a LAN party with a bunch of friends. I installed a bunch of games and such and everything worked fine, but once I brought it home it was having a problem. After a lengthy logging in screen (normally like 1 second) it would show my awesome background... and that's it. No start menu, icons, anything else.
Went to task manager, explorer.exe was running and things were slowly loading, but never showed up. Got rid of explorer.exe and reloaded it, everthing shows. But the main problem is I can't really use my start menu (flashes and then dissapears, same with my docked folders), and some programs won't load at all (namely iTunes, which is really bothering me).
I'm also having cd-rom problems, as even when I have my WC3 cd in the drive it tells me to make sure it's there and hit retry. I'm just using a fixed .exe until I can fix this, but this plethora of problems is really aggrevating me.
I got some anti-virus software and it found legions of infected files and a trojan, got rid of all of them, and my situation got worse. The virus or whatever had infected tons of drivers and so I figured it would solve the problem, but not it's gotten more severe; I can't get into normal XP at all (always in safe mode) and sometimes I can't even get into safe mode (freezes/restarts in bios or while listing harddrives). I've switched out my 2 different ram's and have underclocked from 2300 to 1666 ghz, and I got back into safe mode, but I really don't know what to do.
Is this a hardware problem? Is there a way I can find out? If so, what piece is faulty...cpu, psu, ram? I'll be reinstalling windows XP tomorrow or tonight to see if that helps, but the bios freezing has really gotten me worried. Any suggestions?
