Elixer
This is a single stage snowthrower (~10 years old), and have tried new sparkplugs, new gas, gas cleaner, fuel additive (to get higher octane), some engine deposit cleaner, and it will just never start until I squirt some starting fluid into the sparkplug hole.
Once that is done, it runs perfectly fine until it is out of gas, then, I must use starting fluid yet again to get it to start after the refill.
I thought it might be some carbon deposits blocking gas flow to the plug, but, the plug isn't dirty at all when I remove it to add the starting fluid.
Anyone know what the issue could be?
