snoopy7548
Do you change your snowblower's oil (and you could extend this to your lawnmower) at the start or the end of the season?
I have been changing my oil at the start of the season and I have had no problems, but I'm thinking about doing it at the end of the season before I put it into storage. Fresh oil is probably way better than dirty oil sitting for seven months in the machine. My only concern is the fresh oil going bad (if that's possible) while in storage. I keep my snowblower in my garage which is fully insulated.
I'm thinking of switching to this method for snowblower storage (reverse it for lawnmower):
Winter is gone...
-Run engine until gas is depleted
-Change oil
-Store
...Winter is here...
-Change spark plug
-Fill with gas
-Blow some snow
Winter is gone...
-Change oil
-Store
-Change spark plug
-Fill with gas
-Blow some snow
