snow tires on a car year round in southern california.
holden j caufield
6,324
10
My 05 TL 6spd with VSA Vehicle Stability Assist had 235/45/17 tires on them. My brother wanted to go snowboarding and put new 225/45/17 snow tires on the drive wheels (front) yes I know 4 is better but he's poor. He went a few times and left it as is.
First the ratio isn't off by much but I'm wondering if it will screw things up, vehicle speed by 5%?, traction control, VSA? And how bad is it to run snow tires in front and regular tires in the back?
Thanks
Jumpem
10,757
It will handle worse in the warm/hot weather. And the tires will wear out faster. Hw should put his all seasons back for the non-winter months.
Fenixgoon
33,624
13,320
this. and put the snow tires on the rear, as others have said. it doesn't take much to change tires.
holden j caufield
6,324
10
naw I've never driven in the snow and I don't want them. I came home from vacation and my brother was like I got you 2 new tires. Bad part was he didn't keep the old tires which only had 20k miles. Again I don't drive in snow, I'm in OC socal and don't snowboard. So more snow tires would be even more useless.
Jumpem
10,757
Wow. Your brother would just go get different tires for your car, and the wrong size even.
kornphlake
1,567
9
You'll get ticketed if you drive year round with studded tires. Check with the DMV for the exact date you'll need to have the snow tires removed by, you've probably got 4 months before you'll need to have them replaced. Snow tires are hard on the roads when it's not snowing.
Howard
47,986
11
Punch your brother for being so stupid.
alkalinetaupehat
839
Snow tires don't necessarily have studs in them though. In fact, they typically don't have studs at all.
PhoKingGuy
4,685
You can just get chains...why would he get snow tires? I drove up to big bear with chains on my Jetta, it worked fine....
holden j caufield
6,324
10
bridgestone blizzak tires, no studs. Seems so wasteful to go get 4 new tires. Plus my new years resolution was to not spend anything unless needed (saving for a house).
Fenixgoon
33,624
13,320
A TL is Front Wheel drive. Why would you put the snow tires on the rear? lol
despite the front being both the drive and steering wheels for the TL, losing traction in the rear will cause your car to fishtail uncontrollably.
Throckmorton
16,829
Your brother borrows your car to go snowboarding, and bought snow tires to put on your car's front wheels? Sounds weird to me.
ShawnD1
You drive a TL and can't afford proper 4 snow tires???? wow
I never understand this either. Get a $20,000 vehicle then refuse to buy $800 worth of tires+rims = win :awe:
Oh and driving on winter tires when it's hot out will ruin the tires. My friend bought some winter tires for his car last winter and right now those tires are completely destroyed because he drove on them in summer. He doesn't even drive that much. He probably got less than 15k miles out of those tires.
ShawnD1
This is best shown with a video
http://www.youtube.com/watch?v=EdtAm7RsTmE&feature=related&t=1m27s
Simple physics. The front tires have grip and they are trying to stop. The back tires have no grip and inertia is pushing them forward. What exactly is holding the back tires in position? Obviously nothing is holding them in place. The car will spin around when trying to stop!
holden j caufield
6,324
10
just asking for input, I didn't rotate my tires so the front were worn a lot compared to the rears, the rears look almost newish. That's why he replaced the fronts, no biggie, I'll stop by to get 4 new ones today, anybody recommend some tires for socal. No snow driving for me. Economical long lasting tires, thanks I do some spirited driving my my tires seems to wear out fast in the front, also getting an alignment.
ShawnD1
If you don't drive in the snow, then you could probably just keep the winter tires on until they wear out. Depending on how you drive, that might only take 1 year.
That's probably what I would do. If you replace them right now, the tires will not get any use at all. If you run them until the tread is gone, you get at least a year out of them. That's another year you don't need to buy new front tires ;)
JCH13
4,981
66
Your car is probably going to understeer even worse than it did before it had two snow tires on the front. Unless you get into some snow, then it will oversteer. o_O
There was a thread on summer tires recently and I think the consensus was that Yokohama S.Drive tires were great bang for the buck.
Good luck :thumbsup:
holden j caufield
6,324
10
I was going to get new ones today but it was raining (for some reason it has rained every week this past month) so I ran my errands drove it for a bit. Very quiet and I actually liked the ride. I think I might do this. Seems very wasteful to toss them aside. I'll drive on them for a bit but so far so good imo (in the rain it seemed to handle better than my Pirelli PZero Nero
