openwheel
- Apr 30, 2012
- 2,044
- 17
- 81
I may be in the minority, but I believe people "sense" quality without being able to pick out what draws them to that conclusion. Take for example if you walk into a room where the baseboard nails haven't been countersunk and puttied, the trim was not chaulked, and the dry wall is not perfectly smooth. You may not notice all those tiny details, but they culminate in an old and tired appearance. If you walked into that same room where every last detail was perfect, then you'd have an entirely different perception. Only a tradesman would likely be able to point out all the things that makes the person have that perception, but the layman perceives it none-the-less.
Apple certainly isn't perfect, but they do hold themselves to a higher standard than most companies. It seems to have done well for them and I appreciate that they spend the resources on small details.
There is a thin line between being a snob and appreciating the small details. The line is crossed when disdain is present. I didn't find the article to be too critical, but only drawing attention to what a lot of people may miss when casually shopping for a phone.
This is a terrible analogy. You are describing an incomplete, half finished room as the Samsung S6, while the iPhone 6 is a perfectly finished room. That's a big stretch of a obviously bias opinion.
There is nothing on the S6 that can described as unfinished baseboard or unfinished dry wall.
If you really want to use room remodeling as an analogy, then do you expect all power switches to line up with a receptacle? Would you like the AC register to line up with in-wall speakers? How about AC return to line up with your fire place? How retarded would that room look like?
Come on now.
