Snapshot of Running processes
Toastedlightly
7,214
Is there a program that will give me a snapshot of the running processes on a computer and save them to a log file? I am trying to help a computer illiterate friend with her computer and i have to firgure out what processes are running. BTW: It is WinXP Home. Thanks in advance
-Toastedlightly
talyn00
1,666
You could always try using the TASKLIST command in Windows XP. It should show the running processes in a command line window. You could then use output redirection to dump the contents to a file. You could probably write a small batch file that does this.
The batch file could be something as simple as the following:
tasklist > c:\tasklog.txt
Tasklist syntax
Sonic587
1,146
You could have your friend take a picture of them and send them to you.
CTRL+ALT+DEL to open up task manager...
ALT+Print screen to take a pic, goto MS paint, then click edit and hit paste. Save the files as JPEGs and go here to upload them.
Example.
talyn00
1,666
Example.
I guess that works too, but if the process list is too long you'll need multiple screenshots
