SN95G5 ethernet problems.
CaMSpoon
105
Im having problems where everytime i shut my computer off the drivers for my ethernet which is built into the Shutttle SN95G5 seem to uninstall. So i always have to install the drivers and restart the compuer to get my internet working again. Anyone know the reason for this and how i can fix it?
anyone have the same problem?
RaNDoMMAI
771
i have the same problem, i turn off the comp, and then power on, and the internet doesnt work. but then i just restart and it works again. doesnt brother me too much.
let me know if you find a fix
~RaNDoM
CaMSpoon
105
Thanks for feedback,, great to know its not only me, even though its a pain to go through. I will keep ni touch if i find out how to fix it. : )
Trey22
5,540
Some have reported a connection between HT setting and reliable function of the Marvel chip. Try setting the HT to 4.
Have the latest drivers from Shuttle or the Marvel website?
RaNDoMMAI
771
What does HT stand for? how do i set it to 4?
I have the lastest drivers for shuttle, cant find the marvel ones.
TIA
~RaNDoM
Trey22
5,540
HyperTransport... the setting for it is in the BIOS menu, you might have to dig around a little since I'm not at home w/ my precious (SN95G5).
CaMSpoon
105
I found in in bios but i wanna know what do i lose out on by doing this? I dont wanna lower settings just to fix it.
