- Oct 20, 2004
- 347
- 0
- 0
I recently purchased an SN45G v2 right here on the forums. It came with a 200 watt power supply (not SilentX) and an Athlon XP 2000+.
Other specs:
Corsair XMS Pro Series PC3200 512MBx2 Memory
NEC 16X DVD Burner
MSI Ti4600 128MB Video Card
Hitachi 400GB SATA Hard Drive
I replaced the Athlon XP 2000+ with an Athlon XP 3000+. I then noticed it didn't have SATA so I bought a SYBA SD-SATA150R SATA controller from Newegg. I booted up with my XP Pro format from my last build and after a while it was getting blue screens which was expected because it wasn't a clean format.
I then went into the bios to set the primary boot device to CD-ROM so I could install a fresh copy of XP Pro. I hit F10 to save and exit and when I rebooted there was no video. So, I reset the bios jumper and I got video. No matter what I edited in the bios, i'm unable to get video on the reboot.
I then tried something that probably isn't too healthy. I unplugged my SATA hard drive so that it would boot to CD-ROM and then after it says "Press any key to boot cd-rom" I plugged the SATA drive back in. It worked and XP Pro setup loaded but after the drive was formatted and the setup files were loaded, I rebooted and was greeted with errors about my disk drive. For some reason, I think my SATA controller is causing those errors but then again it may be because of what I did to get Windows setup to boot.
What is happening and how can I fix it?
Other specs:
NEC 16X DVD Burner
