Originally posted by: FIESTARIA
but the temperature never goes aboce 66-67C. do u believe this is the problem?i am using zalman cnps 9500led at the moment. do u think that i have to set fsb values and cpu core back to normal levels??
yes moonboy403 u were right. my score at 3dmark05 was 7750. is this good news or not???
That's a normal score for a 7800gtx in 3dmark05, and that benchmark is mostly gpu-limited. Performance in a real game depends not only on the gpu, but the cpu also, and currently Intel processors perform worse than equivalent A64 cpu's - that's a fact.
THANK ALL OF U VERY MUCH FOR YOUR RESPONSES. i really appreciate that.
in fact i also had problems with thief deadly shadows.prior to that i played prince of persia warrior within and fear(all of them in 1024*765 high quality) and none of them was completely smooth. i definitely don't believe that is a cpu issue. ok... i admit that amd are better but this is not the source of the problem. i have overclocked my cpu at 3.36ghz(fsb 240 and cpu is locked at 14x), memory is running at 640 mhz with dram settings at 3-2-3-8. this is the first video card that i put in my system so,there are no drivers of onother card installed. still, there are no temperature issues. cpu temperature never climbs above 66C full load. i would like to add the fact that i tried playing the game (nfsmw)in 800*600 but there were STILL probs for f... shake!!the only thing that i can think of is that i have my windows installed for about 3-4 months now. do you think that a fresh installation will help?i have read in several posts that 7800gtx is a very good card but i unfortunately haven't seen anything yet!
Originally posted by: DeathBUA
Originally posted by: Insomniator
I really, really doubt a 3ghz P4 is the problem.
http://www23.tomshardware.com/cpu.html?modelx=33&model1=246&model2=202&chart=71
See for yourself.
My 2.4 A64 vs a PD830
Originally posted by: Acanthus
It sounds like you are either missing motherboad chipset drivers, or there is a problem with windows.
Does the Pentium-D require a dual core patch like the Athlon X-2?
Would setting processor affinity help?
