Is there a standard way of doing it? I need to be able to calculate the 1st and 2nd derivatives of this function. It's being used within a newton solver loop, which is why the higher derivs are needed. This is the original implementation; I'm wondering if there's better:
idea: abs(x) \approx x*x/(sign(x)*x+eps), where eps is a small number (e.g. 1e-8)
void
SmoothAbs(double x, double eps, double *y, double *y_x, double *y_xx )
double signx;
// Sign function
if (x > 0.0)
signx = 1.0;
else if (x < 0.0)
signx = -1.0;
else
signx = 0.0;
// Calculate smooth absolute value function
*y = x*x / (signx*x + eps);
*y_x = (2*x - signx*(*y)) / (signx*x + eps);
if( y_xx != NULL ) *y_xx = 2.0*(1.0 - signx*(*y_x)) / (signx*x + eps);
Max uses the following:
*y = 0.5*( sqrt((x-c)^2 + eps^2) + x + c )
void
PXSmoothMax(double x, double c, double eps,
double *y, double *y_x, double *y_c, double *y_xx, double *y_xc, double *y_cc)
double tmp, tmp_x, tmp_c, tmp_xx, tmp_xc, tmp_cc, xpc;
tmp = (x-c)*(x-c) + eps*eps;
tmp_x = 2.0*(x-c);
tmp_xx = 2.0;
tmp_xc = -2.0;
tmp_c = -2.0*(x-c);
tmp_cc = 2.0;
xpc = x + c;
if( (x < c) && (x+c < -1.0e8) ){
/* Protect against subtraction of very large numbers */
*y = c;
if( y_x != NULL )
*y_x = 0.0;
if( y_xx != NULL )
*y_xx = 0.0;
if( y_xc != NULL )
*y_xc = 0.0;
if( y_c != NULL )
*y_c = 0.0;
if( y_cc != NULL )
*y_cc = 0.0;
} else{
*y = 0.5*( sqrt(tmp) + xpc );
if( y_x != NULL )
*y_x = 0.5*( 0.5*tmp_x/sqrt(tmp) + 1.0 );
if( y_xx != NULL )
*y_xx = 0.5*( 0.5*tmp_xx/sqrt(tmp) - 0.25*tmp_x*tmp_x/(tmp*sqrt(tmp)) );
if( y_xc != NULL )
*y_xc = 0.5*( 0.5*tmp_xc/sqrt(tmp) - 0.25*tmp_x*tmp_c/(tmp*sqrt(tmp)) );
if( y_c != NULL )
*y_c = 0.5*( 0.5*tmp_c/sqrt(tmp) + 1.0);
if( y_cc != NULL )
*y_cc = 0.5*( 0.5*tmp_cc/sqrt(tmp) - 0.25*tmp_c*tmp_c/(tmp*sqrt(tmp)) );
void
double signx;
// Sign function
if (x > 0.0)
signx = 1.0;
else if (x < 0.0)
signx = -1.0;
else
signx = 0.0;
void
tmp_x = 2.0*(x-c);
tmp_xx = 2.0;
tmp_xc = -2.0;
tmp_c = -2.0*(x-c);
tmp_cc = 2.0;
xpc = x + c;
*y = c;
if( y_x != NULL )
*y_x = 0.0;
if( y_xx != NULL )
*y_xx = 0.0;
if( y_xc != NULL )
*y_xc = 0.0;
if( y_c != NULL )
*y_c = 0.0;
if( y_cc != NULL )
*y_cc = 0.0;
} else{
if( y_x != NULL )
if( y_xx != NULL )
if( y_xc != NULL )
if( y_c != NULL )
if( y_cc != NULL )
