Smoking hot swiftech HSF!!!
Banana
3,132
23
How's the shipping charge? And isn't the Sunon fan noisy?
edit: Here's one of many positive reviews of this HSF:
OC
Great deal! (But "Smoking Hot" may not be appropriate for a HSF! :) )
lispsux
190
sunon fans are normal. noisy? yes, but normally noisy =)
this woulda rocked if it was the 462 big momma
Gravity
5,685
I like the Zalman heatsinks, much quieter. I wonder how this compares to the stock coolers that come with cpus?
Gravity
kof
408
Gravity
Many people do not buy "stock coolers" but buy OEM CPU's.
human2k
3,563
Originally posted by: M0oG0oGaiPan
This SK-7 for 19.99+ shipping is a good one. This YS-Tech adjustable fan is great with this hs.
Get a 92MM instead, pushes more CFM and its quieter! I like the TT DC which pushes 56CFM @ 35DBA, or if your a little big more daring, the YS-tech 66CFM @ 40dba. I use the YS-tech 66cfm on my XP2100, great cooling and not so loud!
M0oG0oGaiPan
7,858
digitalgamedeals.com
Thanks for the tip. I'll have to try one of those. Less noise without losing airflow is always good :p
human2k
3,563
:p:beer:
EvilYoda
21,198
9
Hmmmm, seeing all this talk about HSFs make me wonder if I should buy a new one or not...it'd be for a crappy old system anyway, so I dunno if it'd be worth it.
edplayer
2,186
the SK-7 does not take a 92mm fan. What would the best choices in 80mm fans be. People keep telling me about the Panaflos, but they do not move much air (sure are quiet though). What would be a good choice in the 35dB range?
DestruyaUR
869
Review
Swiftech's MCXC370 is a quality heatsink with top rate performance and is very easy to install - worth serious consideration.
deeznuts
667
look into panaflo U1A (there are 4 different levels). 47cfm at like 35 dba or something around there.
Jion
17
You guys can stand anything over 25 dBa? That is amazing, my HSF is at 24 dBa right now and im suffering.
DestruyaUR
869
24dba should be near-silent as a whisper is 20dba. You might want to look into changing the fan. It could be failing.
JeffMD
2,026
19
the best heatsink you will buy.. will never be something baught off the shelf. first you need to find an efficent heatsink that has middle of the road noise ratios. I really like the millenium heatsinks as they are high end on heat removale and very quiet compared to likewise heatsinks.
Now you take said heatsink, and install a pointemeter into it, turn that sucker down and youll keep checking to see if your fans still running its so quiet. Unless your overclocking like a somebitch, you should be hitting around 45-55c with the sucker turned down. I do this to all my computer except my main, which has an a7v333 motherboard and uses the QFan chip to slow the fan down automaticly.
edplayer
2,186
what about your hard drive and cooling fan on the psu?
