SMOKING HOT??? Samsung 512MB PC3500 cl2.5 for $186.72 shipped
SupermanCK
2,264
I found this while looking around reading reviews...
It's based in Canada
I don't know if this is the Original or not...but it's a hot deal
https://www.ramstore.ca/showproduct.php?id=107 - won't link correctly for some reason :|
512MB Samsung DDR PC-3500
-Black Aluminum Heat Spreader -Lifetime Warranty
-2.5-3-3 2T Timings
-217(433) MHz
-184 Pin DIMM
-CL 2.5
$284.99/ea CANADIAN DOLLARS = $182.22/ea USD
shipping is free for canadians and $7 for US peeps...that's $7 CANADIAN DOLLARS
so for USA peeps, total comes out to $186.72 shipped!!!
Here
Ramstore Reselleratings
updates: i emailed ramstore and the sales rep told me that this is 3rd party PCB, and he said they didn't do any testing themselves. It was told to them it is PC3500. But they do have life-time warranty. :)
Lizardman
1,990
This is good ram. ITs just samsung 5ns chips overclockable to DDR433 most likely. Samsung doesnt make DDR433 chips yet but the DDR400 ones they have are pretty good. Good price too if you need a 512mb stick, but for I cant justify paying twice the price just because the memory is on one stick and not two.
SupermanCK
2,264
lizardman you are confusing me??? :confused:
it's a 512MB stick...y did you say you are paying double??? i don't get it
Oakenfold
5,740
OMG this is hot!
Wish I had the dough, thanks for the post Superman!
This is intended for serious PC hardware addicts!
No other need apply.
Atif
2,423
11
What's with all the thread-crapping? LOL.
SupermanCK, thank you very much for posting this deal. I've never dealt with Ramstore, but I'm thinking it might be a good time to. I'm going to contact them to ask them what the chip markings are so we can see if it's 'real' PC3500 or overclocked PC3200, I'll post the information here as I get it.
Thanks again for posting this deal, good stuff.
Peace
scoreadeal
633
PC3200 isn't even an official JEDEC standard yet... now PC3500! Wow... Anyways, what motherboards can support PC3500? Seems like this would only be beneficial to those overclocking their motherboards...
KennyH
5,904
Wow, and to think I am still running on PC2100, damn, I need to get with the times huh? ;)
taoofbean
115
Pardon my memory ignorance in this regard, but could someone please take a brief moment to explain in what circumstance one would benefit from PC3500 memory? I am planning on getting a P4 2.4 chipset and DDR but have very little clue why I should opt for more than PC2100 memory. Is there performance benefit if the two chips were run at the same speed?
Ishmael
CyberZenn
462
If you are running both sticks of ram at the same speed and timing settings, then no - theres no difference. If your motherboard supports ram that runs at greater than 133mhz (or you are overclocking), then running 2700, 3000, 3200, 3500 spec'd ram can mean greater memory bandwith
SupermanCK
2,264
pcXXXX means the memory bandwidth...ie pc2100 means it can transfer 2100MB/s or 2.1GB/s
therefore PC3500 = 3.5 GB/s, but the only problem is you have to be able to run your memory at that bus by raising your system's fsb
PC2100 = 266DDR = 133MHz x 2
PC2700 = 333DDR = 166MHz x 2 (note: this can be achieved by either setting your fsb to 166MHz
or if you are running at 100MHz, and you have an option in bios to set memory to fsb ratio to 3:5, then you will get 100MHz / 3 = 33.33MHz x 5 = 166.66MHz
PC3500 = 434DDR = 217MHz x 2, so go figure. You can either push your system to run at 217MHz (1:1), or 163MHz (3:4), or 130MHz (3:5), or 145MHz (4:6), or 109MHz (3:6)
HTH :)
updates, i emailed ramstore and the sales rep told me that this are 3rd party PCB, and he said they didn't do any testing themselves. It was told to them it is PC3500. But they do have life-time warranty. :)
taoofbean
115
thanks immensely for the information. I am not sure how I missed the understanding previously but your insight made it quite clear. Bump for what will be a real hot deal for those with bleeding edge systems and a motherboard who can run stable at strange ratios. Make sure your pci components can be ratioed separately or will handle these settings.
Ishmael
LoverBoyJ
992
thanks for the good deal! :):cool:
gonna try them out. hopefully will be here at the end of the week. :)
Will update u guys! :)
Lizardman
1,990
If this is a third party pcb I would be wary of this deal.
You might consider saving yourself a headach and just buy some true samsung or corsair.
SupermanCK
2,264
hey if it doesn't turn out to be a quality ram...you can always return it...but ramstore has very good ratings thus far...
