Originally posted by: spidey07
no, submersing in a saltwater solution with some other herbs for a short time to impart some flavor into the meat for 24-48 hours.
Maybe you guys call that pickling?
here is the definition of cottage roll. Not sure if it applies to what you are doing:
Cottage Roll
Cottage roll is the top end of the shoulder otherwise
known as the shoulder butt. It is cured in brine and is
not smoked, hence the name ?sweet pickled?. It is
generally purchased boneless and vacuum packed
and is available in a variety of sizes. This
product is uncooked, and, due to its high
salt content, needs to be boiled.
Appearance: Boneless ? Cured/Sweet Pickled
? Uncooked ? Netted
Cooking Method: Remove plastic wrapper from cottage roll,
leaving netting in place. Rinse under cold water. Place in a large pot and cover with water
or ginger ale. If using water, add bay leaf, whole cloves and garlic. Cover pot and bring to a
boil. Reduce heat and simmer for 35 minutes per pound (500g) for cottage rolls up to 3
1/2 lbs (1.75 kg) or 30 minutes per pound (500g) for rolls over 3 1/2 lb (1.75 kg) or until
an internal temperature of 160°F (70°C) is reached. Remove netting before slicing.
Additional Uses: Sandwiches, salads, or in any recipe calling for ham.
