I just got my cable hooked up and I love it when it works.
My problem is when I have my computer plugged into the router and the modem plugged into the router. The pages are slow, often the images don't load I just tried to download a 2.29 meg file several times. When I connect the modem strait to the computer I downloaded the file the first try, and don't have the lag or the can't find server error I keep getting using the router.
I updated the firmware for the router earlier. I am not using the serial or print server at present so I didn't install the software.
***EDIT***
I figure it has to be some kind of software that I don't have set right weather on router or the PC.
Any suggestions will be very much appreciated.
***EDIT***
